steelwoolghandi
Anmeldedatum: 27.12.2006 Beiträge: 23
Verfasst am: 21.01.2008, 16:20 Titel: 1947 Ford COE |
Sorry I have not posted in a while. I have checked in from time to time and I have seen some great work! I love looking thru your gallery and seeing all the wonderful custom bits!
Here is one of my latest Rides: 1947 Ford COE
Chassis:
Body Work:
base coat of paint:
Finished work:
The body was a mold that I made myself from a Die-cast. I hope you like it? |
Verfasst am: 21.01.2008, 17:21 Titel: Re: 1947 Ford COE |
really cool and a clean finish , thumbs up!
steelwoolghandi
Verfasst am: 21.01.2008, 18:30 Titel: Re: 1947 Ford COE |
The Front is a normal bit front end with normal steering. I did run a screw and bolt thru to hold on the front wheels. Becuse of the larger wheels it does not have as tight of turning as smaller bit wheels.
The back end is all custom built with a Super Slicks motor and gears from a slot car. The chassis is built from styrene square tube and flat styrene. The Wheels are the wheels off of the Die-Cast.
The body was made from building the mold then using epoxy casting.
here are some more pictures.
The motorcycle on the back was cut out of a Hot Wheels truck and painted to look more real. |
diets RC-Fan
Verfasst am: 21.01.2008, 18:57 Titel: Re: 1947 Ford COE |
Incredible! Great work!
I love the rims, they look really good on the truck. But why are they mounted clockwise and counter clockwise?
diets - would be a 'bit-fan', if he would not be 'drift king'
steelwoolghandi
Verfasst am: 21.01.2008, 19:16 Titel: Re: 1947 Ford COE |
Thanks for the comments all!
you know Diets I never noticed the wheels were mounted wrong! I will have to switch them around. Thanks for catching that...  |
